breaks and cv boots
Old May 24, 2007 | 06:38 PM
branstone's Avatar
Default breaks and cv boots
here is something novel, went in for tuine up and they say other things are wrong...LOL
according to mechanic: both cv boots leaking and torn although i have never seen any drips on the driveway. we have extended warrenty so just gonna have the dealer fix i guess
breaks under 20% - @ 29,000 miles, sounds maybe right.
so they wanted $450 for breaks? anyone do them at home? anything special about them? i have changed many breaks
Old May 24, 2007 | 06:56 PM
ouTTie914's Avatar
Default RE: breaks and cv boots
If I'm not mistaken the CV boot is filled with grease. You may not see anything on the driveway, but I'm sure it's a mess around the boot.
You definitely want to get that fixed asap!
For the front brakes you need a C-clamp to push the piston in. On the rear you need a piston tool. This spins and pushes the piston in.
A can of Brake quiet is always recommended for new pads.
$450 for brakes?!?! Holy hell!
Old May 24, 2007 | 07:44 PM
branstone's Avatar
yea you are right it should be filled up, just thought i would see something
good info on the breaks, i have weverything i will need then, thanks.
no way am i paying half a g for breaks !
Old May 24, 2007 | 08:02 PM
neur0tic's Avatar
Did the front brakes in about an hour. No different than any other front brakes I've done.
Lazydog
Jan 14, 2013 03:56 PM
Wintermute
Sep 21, 2008 11:31 PM
mackers
Oct 19, 2006 02:55 AM
