Broken vacuum item! What is it?
I was looking around for vacuum leaks today & found a braided line that looked pretty dry and crappy....so I set out to replace it.
I had no trouble with the end that looked crappy...it was loose anyway. But when I went to take the other end off (which attaches to a device that has an electrical plug attached to it) I managed to snap the nipple off inside the piece.
I dont know what this thing does....or what it is called but I will need a replacement ASAP.
So, I will try to explain where it is & maybe someone knows what the thing does.
The small thing is attached under the plate that bolts to the side of the intake & holds the dip stick also. It was held on the plate with 2 phillips screws & has a vacuum inlet and then the braided line that ran up to something which I assume controlls boost or fuel pressure.?.
The small unit has a PA66 on the electrical plug end and 00T278 & 037 906 283 8 & 7.22393.00 APG on the side of the unit....made by pierburg PA6-6F30<1 on the other side.
So....anyone have a guess what this thing is or what it is called?
Please help...so I can drive this thing again.
Thank you,
Eric
Thank you,
Eric
That is the valve I am talking about....under the plate.
I snapped off the hose barb that faces down.
How important is this valve?
Can I cap off the vacuum line or run it directly to the other end & still drive my ride until I get a new valve?
What does the vacuum line feed air to on the other end?
Thanks so much,
Eric
Thanks so much,
Eric
can you physically see the part that snapped off in the pics above? it's really hard to know exactly where you are talking about. most likely you would be fine to cap it off for a short period of time but is really har to say. either take a picture or use one of the pics above and circle where the issue is...or read this. http://forums.vwvortex.com/zerothread?id=3111538 and go from there...that stuff is safe to do
The electrical plug you see in the last picture connects to the solenoid I am speaking of and the vacuum line you see bending up towards it is the one that connects to the barb I broke off of mine.
If the other end connects to the diverter valve then could I run it directly and bypass this thing alltogether or at least temporary?
What do you think?
Thanks,
Eric
What do you think?
Thanks,
Eric
No....not the diverter valve. It connects to another vacuum powered canister that bolts down with 2 bolts to a metal hose which goes down to the back side of the motor. EGR possibly?
Does anyone have a vacuum schematic for my ride?
Thanks,
Eric
Thanks,
Eric
Thanks so much,
Eric
Thanks so much,
Eric
I removed the vac line from intake nipple & ran a new line up & teed it to suck both the dv and the combi valve. I ran the codes & now I have 2 more.
Now I get P1432 (air vlv open) & P1287 (bypass vlv open)
Do I need to keep the solonoids plugged in to keep from getting codes?
Not sure but feels like one step forward 2 steps back.
I put a vacuum gauge on inline to see what I am getting and found that I have just below 20" of vacuum. Seems to be very steady on the gauge also.
What should I be getting on the gauge?
Thanks,
Eric
p.s. I also broke the oil dipstick in the process & due to my white trash upbringing I was able to fix it with a 3" piece of copper tube that was just the right size to couple the 2 pieces & still let the dipstick go by once I fine tuned the orange plastic guides on the side!
LOL!
Thanks,
Eric
LOL!
