Cams
Old Jul 26, 2007 | 11:13 PM
cincyTT's Avatar
I'm make believe
Default RE: Cams
on what applications and power levels?
Old Jul 26, 2007 | 11:17 PM
neur0tic's Avatar
Default RE: Cams
am i looking for 4 cylinder 5 V mechanical or hydraulic?
Old Jul 26, 2007 | 11:20 PM
neur0tic's Avatar
Default RE: Cams
ORIGINAL eurospec site:
4 Cylinder 5V Mechanical
ECM 109 3703
5V Mechanical w/Gear
274/288
10.50/11.64
106
$800
4 Cylinder 5V Hydraulic
ECH 109 058 268/0
5V Hydraulic w/Gear
268/260
9.10/10.40
110
$495
ECH 109 3601
5V Hydraulic w/Gear
250/266
8.21/9.95
110
$800
058 198 021/022 AR
5V Hydraulic w/Gear
210/210*
8.75/10.2
110
$495
I should have slight HP gain and a little more torque loss. Overall it'll be a loss until I get a higher flow head, I.M. TB, and turbo correct?
I'm doing the Internal and External hard parts with the assistance of a tuner friend. However, he is more familliar with supras, 300zx, and honda engines. Anywhere I can get some good 1.8t tutorials for internal upgrade theory and mechanical specs and institutional knowledge?
Old Jul 26, 2007 | 11:22 PM
cincyTT's Avatar
I'm make believe
Default RE: Cams
ORIGINAL: neur0tic
everything listed will not give any gains (very minimum at best) until the turbo is increased.
Old Jul 26, 2007 | 11:24 PM
cincyTT's Avatar
I'm make believe
Default RE: Cams
dont quote me on it but i think its hydrolic
Old Jul 26, 2007 | 11:44 PM
neur0tic's Avatar
Default RE: Cams
Hmm... hopefully one of the tech's can chime in with the answer on which camshaft set would best suit this application.
Old Jul 26, 2007 | 11:48 PM
cincyTT's Avatar
I'm make believe
Default RE: Cams
send bob an email at the link i provided up top. He will help you get the best match for your application (well soon to be).
Old Jul 26, 2007 | 11:59 PM
  #18
neur0tic's Avatar
Default RE: Cams
which link? the eurospec link you posted or the QED power link you posted?
Old Jul 27, 2007 | 12:07 AM
  #19
cincyTT's Avatar
I'm make believe
Old Jul 27, 2007 | 12:49 AM
  #20
225tt's Avatar
Default RE: Cams
Yes we have hydrolic lifters those are the ones that you are going to want to get. The Cat Cams are what most and I say most 1.8T engine builders go with. Heres a good site to find out more info. If you have VVT or not and the part numbers the lift, etc...
http://www.qedpower.com/catcamspage.htm
