Can I replace these hoses with silicone?
Old Mar 26, 2009 | 11:19 AM
Mr.T's Avatar
Default Can I replace these hoses with silicone?
I believe it is the Evap system but I see that is has a service port that has a tag that says "test 1 psi max" with a green cap (i have highlighted the lines on the left of the pic). I wasn't sure if it was pressurized. So is it ok to replace? I have another line highlighted but i think it is bigger than 8mm. I hope its ok if i borrowed this pic. Thanks
Old Mar 26, 2009 | 11:33 AM
cincyTT's Avatar
I'm make believe
You can replace it with silicone no problem or just remove all of that stuff if you want. Just make sure to keep the one way valves going in the correct direction.
villacorta32
Mar 25, 2012 10:02 AM
NaudifreakTT
Jan 25, 2010 09:53 PM
VTEC_THIS
Jan 5, 2009 11:39 PM
mmapro23
17
Dec 24, 2008 03:57 PM
02audia41.8
Jul 28, 2008 09:13 PM
