Can somebody help me...
^ my ESP/ABS light turns on intermittenly.
if we both have the same symptoms, then it's NOT limp mode. you will feel the drastic decrease of power in limp mode. i mean if you're completely stock and not running an MBC, then i would highly doubt u got into limp mode.
the only mention of the lights being turned (ABS/ESP) on in the manual, states that your rears will lock up under heavy breaking and 'must be checked and repaired at your local audi dealership'.
You could try taking a look at your wheel speed sensors. They're magnetic, and pick up junk off the roads until it clouds the signal. I've had that throw a ABS light (no ESP for me). All it takes is some pressurized air to blow the debris away.
