Car is falling on its face at full boost, possible misfire
Old Aug 12, 2007 | 09:48 PM
eliTTe's Avatar
Default Car is falling on its face at full boost, possible misfire
Recently I have noticed my car acting up when I try to drive it at full boost, not all the time but usually when I give it enough gas to reach full boost aroung 3k it just kinda stutters and won't accelerate worth a crap, and today I actually got what seemed to be a misfire... last time I was having misfire problems, I changed the plugs and it was fine
So I figured I'd change them again eventhough there is only 6k miles on them but I guess it wouldn't hurt since they are the copper cored bkr7e's... well I changed the out with new bkr7e's, and I noticed this time the tips of the old plugs were a grey color, usually in the past my old plugs have been a dark red/rust color, hmm? Well I changed them and the car still does it,it didn't fix anything...
I'm thinking it might be these $hitty NGK bkr7e plugs, eversince I switched to them from factory I have had problems... what do you think??
Old Aug 12, 2007 | 10:19 PM
ouTTie914's Avatar
Default RE: Car is falling on its face at full boost, possible misfire
Are they correctly gapped?
Old Aug 12, 2007 | 11:04 PM
eliTTe's Avatar
I have been gapping them to .028 which is what I've read to gap to...
Old Aug 12, 2007 | 11:16 PM
theTTkid's Avatar
or coilpacks?... i dont know though because when i blew two of mine the car barely ran..
Old Aug 13, 2007 | 12:01 AM
cincyTT's Avatar
I'm make believe
They should be grey, i think you must of put in some additives to make them turn the redish color. Your gap is correct. You either are having coilpack(s) problems or possibly a maf problem. Try unplugging the maf for a spin.
Old Aug 13, 2007 | 12:05 AM
eliTTe's Avatar
thanks cincy, I'll give that a go
Old Aug 14, 2007 | 08:11 PM
chosos's Avatar
how would you know if a coil pack is going?
Old Aug 14, 2007 | 09:11 PM
theTTkid's Avatar
the car will be sluggish, not as responsive... its almost like driving without a cylinder
Old Aug 15, 2007 | 11:21 AM
cincyTT's Avatar
I'm make believe
ORIGINAL: chosos
after all the crappy driving, you get is scanned and it says missfire in cyl X and when you move it to cyl Y and the code then moves to cyl Y, you have a bad coilpack.
Old Aug 15, 2007 | 09:07 PM
achTTung's Avatar
Stock intake piping? Could be the turbo collapsing the soft parts of the intake.
