CEL and emissions test...
ORIGINAL: Mac_17
Yep it will fail the test. Go to the shop and get it cleared and fixed because it takes 75 miles for them to pass it.
75 miles to set it up? that's new but then again im in the UK ( when you reset a fault code it doesn't date stamp it ) and if the car is warmed up after a good run and passes the emissions what does it matter if it was done at the test center? strange test machines you guys have over there
edit: good pointdiehlryan what was the code?
MAF has its own fault code and the codes you mention are intermittent but it has been known for the MAF or vacuum line which would effect the MAF to cause misfire, clear the codes and see if they come back and if they do look for vacuum/air leaks
