CEL went out but still not right
Subscribe
Nov 21, 2011 | 10:32 AM
I had posted that I had a CEL with code p0171 a few days back but never got it figured out. Well the CEL ended up going out but I have noticed a deteriorating condition of the car not starting right from a dead cold. I noticed that the hum of the pump primming works intermittently and last night although 60 degrees out it cranked for several seconds before starting.
I am assuming puel pump considering im at 160k and its never been replaced? But would that have thrown that code then disappeared? I know usually when they go they just stop working which usually sucks but maybe I'm lucky and its dying a slow painful death.
Reply
Nov 21, 2011 | 12:18 PM
How olds the filter? Fuel filter is supposed to be changed every 10k miles or so. These can lead to slow starts and lean fuel conditions.
Reply
Jan 12, 2012 | 09:56 PM
my 01 jetta had 199678 on the pump, change fuel filter as stated above even though its prolly not listed a maintenance item, $10 same filter as my 01 turbo jetta
Reply
Jan 13, 2012 | 05:39 AM
I would suggest the same. Replace the filter and then the pump. Before the Fuel pump dies, better replace once at all.
Reply
Jan 13, 2012 | 12:49 PM
Hi guys, wondering if anyone can help me. My CEL has flashed a couple of times when ive been accelerating? It flashes for about 5-10 secs and then goes off. Its happened only a couple fo times and then stays off. Any ideas?
Reply
Jan 15, 2012 | 07:07 PM
Quote: Hi guys, wondering if anyone can help me. My CEL has flashed a couple of times when ive been accelerating? It flashes for about 5-10 secs and then goes off. Its happened only a couple fo times and then stays off. Any ideas?
Misfire
Reply
Jan 16, 2012 | 10:23 AM
many possibilities
a vagcom scan could find the answer, i bought mine after shortly buying an 01 jetta 1.8T, it does soooo much, many things i do not know how to use, but there is many simpler uses, vag wiki even gives likely causes to troublecodes, i works on almost all vw+ audi vehicles, i have already diagnosed issues with my recently purchased TT, you can try to find someone near you for a scan, maybe autozone if they cover vag cars, my buddy's garage can't scan vw's without extra cost software for his $10,000 snap-on setup!!
Reply
Subscribe
