AudiForums.com
-   Audi TT (https://www.audiforums.com/forum/audi-tt-7/)
-   -   central locking system and dome lights problem! (https://www.audiforums.com/forum/audi-tt-7/central-locking-system-dome-lights-problem-128937/)
SmoothTT Mar 31, 2009 12:26 PM
Ok so my central locking system does not work. I can't lock my car from the inside and also my dome lights and visor lights dont work either, but that's only when my doors are closed. If I open either of my doors they do turn on but other wise they don't. Anyone with the same problem? FYI I have checked the fuses.
I'm open to any suggestions. Thanx for the help
2000 ttq 180hp
XCLR8TT Mar 31, 2009 12:57 PM
Run VAG-Com first to see if there are any faults noted.
SmoothTT Mar 31, 2009 10:19 PM
ok i know going to auto zone is not the same as a vag-com, but they checked for codes and nothing..
TTravis Apr 1, 2009 10:48 AM
I had the same problem. See https://www.audiforums.com/forum/sho...d.php?t=124481
That had the solution for me...
Now, I am just trying to figure out what that thing in front of my Central Locking Unit is supposed tobe (it's not there).
lennyauditt Apr 1, 2009 11:33 AM
ok with the sent lock...are you trying to lock the doors with the doors open??...because you CAN NOT. lock the doors with that and get out. you have to lock your car with your Key/remote
SmoothTT Apr 1, 2009 01:57 PM
no i cant lock or unlock my doors when im inside the car with the doors closed. And on top of that my remote lock does not work either. But i will try to find a central locking system. Thanks for the help TTravis and everyone else..i will update
lennyauditt Apr 1, 2009 03:23 PM
reset your key remote theres instructions in the owners manual
SmoothTT Apr 1, 2009 05:13 PM
i did but it wont work..i tried replacing the batteries on the remote as well..so my next step is to replace the central control module
lennyauditt Apr 1, 2009 05:41 PM
well what in the hell did you do!!! ;) theres been a few ppl that have had this problem and they reset there key and it was all good.!
you can lock it with the key right? not the remote... but the key?
