Changing the Thremostat in my TT
Old Sep 14, 2006 | 01:26 AM
nickneipp's Avatar
Default Changing the Thremostat in my TT
Can anyone tell me how to replace a thermostat on an Audi TT 00'?
Old Sep 14, 2006 | 01:46 AM
JewbinTT's Avatar
Default RE: Changing the Thremostat in my TT
hey email me at jrubin@sc.rr.com I have the bentley manuals i might be able to get the instructions to email to you.
Jeff
PS 225 or 180
Old Sep 17, 2006 | 11:52 PM
JewbinTT's Avatar
Did you get my fax?
jeff
Old Oct 25, 2006 | 08:14 PM
RussTT's Avatar
Its definilty not that easy requires alot of removing things and tight spaces prepare for a 2-4 hour job depending on how technical you are
Old Oct 25, 2006 | 09:49 PM
MeanAudiA6's Avatar
just have to remove the intake manifold and then the coolant hose going into the engine block. the thermostat is inside that hose
Old Oct 29, 2006 | 10:29 PM
MeanAudiA6's Avatar
its also located by the alternator (just right of it in that hose going into the block
Old Dec 2, 2006 | 02:50 PM
DenimTT's Avatar
How do you remove the intake manifold without wasting all those goofy one use hose clamps? I've been in there fiddling for hours trying to avoid dropping the manifold off, but its looking grim.
Old Dec 2, 2006 | 03:45 PM
XCLR8TT's Avatar
It's possible to do without removing the manifold. You will need a variety of extensions. Here is a step by step that MarTT put up on Audiworld...Take your time, it's not a real tough project. Just cramped space.
Old Dec 2, 2006 | 03:51 PM
techbod's Avatar
[IMG]local://upfiles/12092/24FD2B8727444B1B89FE02A73A36AD46.jpg[/IMG]
Old Dec 2, 2006 | 03:55 PM
techbod's Avatar
Default RE: Changing the Thermostat in my TT
my apols there I was thinking coolant temp sensor cough which by the way is where the stat is or should be
