Chipped?
Old Oct 29, 2007 | 10:56 PM
TracAction's Avatar
Default Chipped?
Ok So I was putting in all my new parts and I pulled the ECU tonight to send itout in the morning to get it chipped at Stratmosphere. Well when I FINALLY got the wiper arms off I got the ECU out and then I noticed a little sticker right below the factory sticker said "GIAC equipped off road use only"
Does anyone know where I can find a Dyno graph for the GIAC it is odd that they don't have one on their site, which is one reason I looked past when deciding on what tune to get not much in they way of numbers put out by them?
The tuneI wanted is here
http://www.oct-tuning.com/shop/catal...ge.php?pID=149
I like the up front flat torque which is good for AutoX (basically it didn't have the highest numbers but did have the most fastest)
so I am back to looking for a Dyno graph of the GIAC 180tt Prefer Quattro if anyone knows where to find one.
also I know GIAC has the hand held controller that I could get and maybe get an new version and dosent the hand unit allow more input like boost control and such... (their site is down when I am typing this) does anyone have this and how do they like it?
and yes a boost guage is one of the things I am in the process of putting in this week in my spare time. So I want to try to get some figures so when I get it in and see whatI am actually boosting I can decide where to go.
thanks guys
Old Oct 29, 2007 | 11:00 PM
cincyTT's Avatar
I'm make believe
Default RE: Chipped?
dont think your going to find a 180q dyno for any chip. But you should be around 160awhp and 200tq. Knowing giac, you should be 18-20psi and have a good amount of timing which should give you a good deal of power after peak tq and as the boost starts falling off.
Old Oct 29, 2007 | 11:10 PM
quattro411's Avatar
my apr is "rated" at 209hp or 210hp i think 93 oct program
Old Oct 29, 2007 | 11:13 PM
TracAction's Avatar
right but when does it start producing what lvl of torque like APR has a graph to show this and so does O.CT and the O.CT is putting out 320tq at 2300rpm i know this is prob at the crank but still looking to see where I am at
I can tell you from the butt dyo factorI don't thinkI am at either of thoose levels now
Old Oct 29, 2007 | 11:18 PM
cincyTT's Avatar
I'm make believe
320tq is total BS. Most chips make it around 230-240tq and around 2500-4000rpms.
Old Oct 29, 2007 | 11:23 PM
TracAction's Avatar
well if you looked at the link the chart list 320nm torque which calculates back to 238ft/lb and that is at 2300 rpm but that is also the peak and stays flat there then dies off when the hp starts to rise.
Old Oct 29, 2007 | 11:25 PM
cincyTT's Avatar
I'm make believe
that sounds about like the rest of the chips then.
Old Oct 29, 2007 | 11:40 PM
theTTkid's Avatar
a chip is a chip is a chip...
Old Oct 29, 2007 | 11:41 PM
TracAction's Avatar
here is the APR graph for both 225 and 180 (the 180 charst are wrong and both show HP gains only no torque
http://www.goapr.com/Audi/images/dyno_TT_stage_i.gif
REVO power graphs (have to click on them on the site)
http://www.revotechnik.com/products/....aspx?pvID=349
O.CT HP and Torque Graph
ok found the GIAC chart
http://www.giacusa.com/images/tt_180_dyno.jpg
there are some differences in how the power does come on
Old Oct 29, 2007 | 11:44 PM
cincyTT's Avatar
I'm make believe
All are about the same. Giac has been shown to be the faster of the stock chips, but as said before, all chips with = psi are going to perform about the same.
