Cleaning day.
Old Jun 30, 2007 | 06:13 PM
cincyTT's Avatar
I'm make believe
Default Cleaning day.
I have had some problems with startup the last few days and found out it was my maf. So today i decided to clean it amoung other things. Unfortunatly my maf is gone and will be in the need of a new one...ANYONE WANT TO SEND ME A MAF FOR AN ATC? [:@]
In my quest to find the problem i cleaned my TB which appeared never to of been cleaned, very nasty. The TB also had some oil resting in it and since i have a catch can i knew i had to have oil pooling in my ic. So i got to rip off my front bumper and drain about 1/4cup of oil out of it and cleaned the inside with the TB cleaner also to remove as much oil as possible.
While the front bumper was off i noticed that the scoop for the ic was pretty much blocked off by the passenger side alien. It covered about 80% of the airflow so that part was removed and the hose line wasplugged. Now i should actually havesome coooling in the ic now that it will see airflow and is now 99.99% oil free.
So again, anyone want to send poor little me a new MAF?
Old Jul 1, 2007 | 03:22 AM
TSRgeneral's Avatar
Default RE: Cleaning day.
Hey. I might just have one for you. Im not sure if my car is ATC but i have a extra maf i took off my car last year. Its still good but i bought a new one to replace it. i have a 2000 TTQC. how do i find if my car code is ATC. mabye you have something to trade ?
Old Jul 1, 2007 | 03:34 AM
Anos's Avatar
just out of curiosity Cincy - Do you have a NAPA (or whatever the other chains are out there?) close by? I went to my NAPA and got a Refurb OEM Bosch MAF w/ lifetime warranty for $93. next day S&H was like $5 - works great =) If I had my old one still...ida sent you mine =/ it was an ATC Bosch MAF
Old Jul 1, 2007 | 12:56 PM
cincyTT's Avatar
I'm make believe
all 2000's and some early 01's are ATC engine code. You can see your engine code on a tab next to the timing belt on the head.
I will call my local Napa and see what they can do also.
Thanks guys.
Old Jul 2, 2007 | 05:37 PM
cincyTT's Avatar
I'm make believe
a nice pic of my now unobstructed ic pathway. i dont have a before pic but if you look at yours, you will see what i mean.
[IMG]local://upfiles/28034/50D3D4C97C344A9D8050D2561A204E8A.jpg[/IMG]
Old Jul 2, 2007 | 05:42 PM
TSRgeneral's Avatar
Good mod. I never new about that black backin until i actually took out the Grill. should let alot more air flow over the IC
Old Jul 2, 2007 | 05:46 PM
cincyTT's Avatar
I'm make believe
its only 3 screws (well 5 but i got lazy and cut the loop holding the actuator and plugged the ww line. Add the extra airflow with no more oil sitting in there and i shouldnt heatsoak as fast.
Old Jul 2, 2007 | 06:12 PM
AudiOso's Avatar
Hey Cincy... you have the side mount IC still? It looks that way from the pic. When are you gonna go to a FMIC? That's what I want to do next on my car after I save some $$ up.
Old Jul 2, 2007 | 06:19 PM
cincyTT's Avatar
I'm make believe
im not sure if i want to go with a fmic or goair 2 wateric. When i go BT and only have 3' of ic piping should take out some lag on a 50trim. Its still up in the air for now.
Old Jul 3, 2007 | 03:42 PM
MeanAudiA6's Avatar
so whats the deal with that turbo in your pic gallery? what car was all that on?
