Climate control problem
So, I have a 2001 225. I just bought an aftermarket radio and went to install it a couple weeks ago. This was before I read that you need to actually pull power from the area in the lower dash, so I was just pulling power off the stock harness with the adapter that Metra makes.
Long story short, after I had everything ready I reconnected the negative battery terminal, I was holding the new head unit and had the connections twisted and taped for testing purposes, and pulled a little bit too far and the power connection came loose and sparked on the metal posts on the side of the center console. The climate control lit up when this happened.
So now, my climate control doesn't work; it won't turn on. It illuminates fine with the lights on. I replaced the #3 5a fuse (which I think is just for the lights, but I wanted to be sure), and the #25 25a fuse in the cabin fuse box. Then I ordered another used climate control from LKQ with the same part #, and I'm still getting nothing.
Also, I had my stock radio back in and it wouldn't shut off with the car anymore, I had to turn it off manually. Definitely related to the sparking incident, but dunno if it's related to the climate control.
Anyone have any idea what the problem might be? Would running power manually be a good idea, or something like that?
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
I jumped the AC pressure sensor with a papper clip to check if that would make my compressor clutch run and after that no power on the climate control unit!!, seems to be death and having the same exact issue with the radio will only turn off manually! I'm hoping you found out the fix for this before I dole out some of my hard earned Dollars to the stealership!!
thanks for your advise any help is greatly appreciated!!
I did the same exact thing with a new radio install and and the climate control just stopped coming on and the interior fans dont work either. I haven't noticed if the radiator and ac fans stopped working either but I will look into that. Fuses are all good... I am a bit lost. There was another thread stating that there was a small fuse box behind the climate control but I havent taken the center dash apart to inspect. Here is the link:
After a short,: no power to radio, climate control.. - Page 2 - AudiWorld Forums
And updates would be nice
Thanks
Thanks
