Cluster question not about settlement
My cluster does not display MPG or radio station info. All other cluster functions work fine. I have a 2000 180 FWD. Do some of the early cars not have those functions, or is my display faulty?
The MPG thing I have no clue on, the radio info... I turned mine off (occasional fading of the upper left corner I got tired of looking at), assuming you don't have any other issues, it might just be a matter of coding the module for the instruments. I did it with Vagcom.
I have a 2004 TT and the lower portion shows Miles left until empty. I never even knew I could change it to mpg.Where do you change it from miles left to mpg? I guess I have to look for it
in my owners manual.
Rocker switch on the end of the wiper stalk, might also add then that the button on the underside of the stalk is the on/off/reset button for the trip computer. Press it, and it turns the display on/off, hold it, and it resets the display if its showingMPG, Ave. Speed, or Total drive time.
ORIGINAL: achTTung
