Code P1128
I drive an 01 TT Roadster yesterday on the way home my check engine light turn on...so i went to AutoZone to check out the problem (damn they charge for using the OBD reader) after that I checkto see whatswrong with it..then it the code pop up P1128..Car isrunning lean andsomething air fuel...So I went back andreturn the OBD reader and ask them what could cause the problem ..
1.O2 Senor
2. Air Leak
I check all my horse and check and tighten all my intake screws and crimps
Had anyone had this problem before: if do how did you guys fix it..
by the way I only had few mod on the car like intake and BOV from Forge (forge Splitter)
1.O2 Senor
2. Air Leak
Try cleaning your MAF first. It's either bad or dirty. Pick up a can of CRC MAF cleaner at AutoZone and remove the MAF. It's the black tube with a electrical connector hooked to the tube leading out of the air filter. Spray everything down really good, let it dry and reinstall.
