cel code P1128?
Old Oct 9, 2007 | 05:10 PM
yhkimdc's Avatar
Default cel code P1128?
Can anyone help me with this? I put in the decoder and it states P1128. I am not familiar with this code. I was surfing the internet and it said that the code would be MAP low emission? Can anyone help me with this problem and what I could do to resolve the cel from continuing to come on. It seems like it comes on after I drive about 20 miles. I have 2000 A4 1.8Q.
Old Oct 9, 2007 | 08:36 PM
MrTsB5A4's Avatar
Default RE: cel code P1128?
The MAF sensor could be bad. But the P1128 is triggered when the fuel mixture is so lean the O2 sensors are constantly in the rich position. I would look at the O2 sensors first. Then check the fuel injectors, fuel pump pressure and volume. Replacing the fuel filter is a good idea also. Vacuum leaks could cause the lean condition as well. I would make sure there are no vacuum leaks and that the oil cap and dipstick are firmly seated.
I typed the code into google and this came up on a vw/audi site, good luck
Old Oct 10, 2007 | 02:51 PM
yhkimdc's Avatar
thank you very much. i will check on these things and let you know
pwillaby
Jul 29, 2014 10:21 AM
mandito219
Jul 17, 2009 08:53 PM
Stouffer
Jun 28, 2008 02:16 PM
BLK_A4
Mar 11, 2008 11:08 PM
gksboi329
Feb 16, 2008 05:21 PM
