Convertible top replacement
There are a few things you will need to get a hold of to do this job. First, you will need to order two new stopper sets for the bottom bow. You can find them online for $20 per set. The set includes a new black plastic stopper and 2 giant pop rivets. That said, you will need a giant pop rivet gun that can handle 1/4 inch pop rivets ( usually not found at Home Depot). You can gate a regular pop rivet gun at Home Depot, or wherever, and expect to use 1/8 inch pop rivets on the smaller areas of the bow that has them. Another thing to get is double sided adhesive trim tape for hooking the top to the bows before replacing the brackets that screw into the bow. When replacing the brackets on the middle bows, try not to over stretch them or it will create dimples in the top. Another thing to think about while doing this is removing the entire bow structure from the car. I kept it on the car thinking it would have been easier, but it was a giant pain in the ***. Removing the bow structure also helps you get to the hard to reach angles better while protecting the glass window. There are some diagrams out there online that can help and a procedure in the Bentley manual that shows how to remove the top, but if you go slow and document your progress, it shouldn't be too hard. Hope this helps.
This is a link to a parts store for a dealership that I found. 2003 Audi TT CONVERTIBLE/SOFT TOP Frame & components Strut assy Audi Henderson Parts
It isn't much, but I was able to use this diagram and the one in the Bentley manual to get the job finished. I hope this helps. Good Luck.
I find it odd we are all suffering from the same problem, but no one is speaking to the root cause. Audi and VW convertible tops are of inferior quality, the glass falls out. If you purchase the factory replacement top, plan on this failure reoccurring after 5 years of regular use. The aftermarket tops appears to last longer than the oem original. Interesting symptom don't you think.
Clinke...I see you haven't been on in a few years, but I'm hoping you get an email of this.
Where was the shop you had sew the new rear window on? I just bought a 2002, and got it for a steal because the seem around the rear window is giving way. Don't want to drop $1,500 or more on a full replacement.
Thank you,
Thank you,
Hey guys I'm new to the forum but I just thought I'd add this link to a youtube video on how to remove the top for anyone considering DIY.
I just recently installed a new top on my 04' TT and it was hard to find information online on how to remove and install.
Here's the link
Also, I did find one company that sells the top with instructions and I called to buy the instructions only (because I already had my top)...they declined the offer.
Hope this link helps someone out!
Here's the link
CarsVapeandDisney
B8 Models
Jul 6, 2015 12:46 PM
chastt
Jul 26, 2010 07:17 PM
