Creaking Noise
Old Jul 22, 2007 | 02:34 PM
shkenned's Avatar
Default Creaking Noise
My brother-in-law and I are going to be doing the timing belt soon, and while we're under the hood, I was hoping to take care of the creaking noise in my suspension. When hitting bumps in the road, my car squeaks like an old creaky door. Even if i'm going at extremely slow speeds, it still creaks. Any ideas as to how I can figure out what needs replaced to help get rid of the creaking?
Old Jul 22, 2007 | 02:48 PM
diehlryan's Avatar
Default RE: Creaking Noise
sway bar bushing.
Old Jul 22, 2007 | 02:53 PM
shkenned's Avatar
How would I go about checking that?(i.e. - where's it located?)
Old Jul 22, 2007 | 03:11 PM
diehlryan's Avatar
Old Jul 22, 2007 | 03:20 PM
racer_x's Avatar
my doors sounded like... creaky old doors. This is totally off topic, but if any of your TTs suffer from the same ailment... get them fixed! Don't make the rest of us look bad :P I used Liqui-Moly grease, which I just happened to have laying around with a bunch of Porsche parts in my garage. Works like a charm.
Old Jul 22, 2007 | 03:35 PM
shkenned's Avatar
Alright, got some pics here.....maybe this will help:
Driver's Side:
Passenger's Side:
Anything look outta the ordinary? I couldn't tell much about driver's side, but I thought passenger's side looked bad....i really don't know though.
Old Jul 22, 2007 | 05:51 PM
neur0tic's Avatar
they look like sway bar bushings. I would replace the front control arm bushings. those things are like foam and when they get old... they go to ****. you can get some polyurethane control arm bushings on ECS and ttstuff for fairly cheap too. another option is to go to the modshack.info site and go with the DEFCON kit that already comes with polyurethane bushings for the control arms. not only will you get rid of the creak... but you'll have a super-sweet and super-tight suspension. I cannot wait until I get my DEFCON 1 upgrade.
Old Jul 22, 2007 | 06:21 PM
shkenned's Avatar
Those pics are of the sway bar bushings, just thought i'd take a pic and see if someone would see something that jumped out to em...idk....
Old Jul 22, 2007 | 08:46 PM
diehlryan's Avatar
I gave you a link for an AUDI TECHNICAL SERVICE BULLETIN with the exact symptoms you are describing and you're still up in the air on it?
Its a well known problem.
Old Jul 22, 2007 | 09:06 PM
MeanAudiA6's Avatar
just replaced mine and no more creaking!!! got them from ttstuff.com poly bushings
