Damage From Non-Synthetic Oil
Old Jan 9, 2008 | 06:42 PM
beachchair's Avatar
Default Damage From Non-Synthetic Oil
I always use synthetic oil since buying my TT, however I bought it used, and have my doubts if the previous owner was diligent about always using synthetic oil. The car has 35K miles, and I am concerned if there is potential damage from using regular motor oil. Is damage a possibility, and is there any way to correct it? I'm thinking very frequent oil changes, 2-3 times, to flush out any sludge build up. Any thoughts?
Old Jan 9, 2008 | 06:44 PM
eliTTe's Avatar
Default RE: Damage From Non-Synthetic Oil
lol your car is just a baby at 35k... no worries.
Murderface's Avatar
Well if you're afraid he sludged it up, you can run solvents through your oil such as seafoam.
Old Jan 9, 2008 | 06:46 PM
beachchair's Avatar
ORIGINAL: eliTTe
Yea, but she's my baby.
Old Jan 9, 2008 | 06:49 PM
cincyTT's Avatar
I'm make believe
the ill effects on non syn oil would take more than 35k miles to build up. That is unless it was driven 10k+ mile between changes, which i doubt it was.
Dont worry about the past, there shouldnt be any harm done. But the only time reg oil should be used is to break in the engine and only then
Old Jan 9, 2008 | 07:02 PM
auditech79's Avatar
Hell the dealer doesn't even use synthetic oil in the 1.8T on the TT, only on the A4 1.8T.
I think you have nothing to worry about.
Old Jan 9, 2008 | 09:38 PM
beachchair's Avatar
ORIGINAL: cincyTT
That's a new one on me. Why would that be?
Old Jan 9, 2008 | 09:41 PM
beachchair's Avatar
ORIGINAL: auditech79
It's interesting, but not surprising, that the dealer doesn't use synthetic.
Regarding synthetic oil, my Bentley Manual states:
"Observe oil specifications given in tables above. Use only synthetic oils. Oils for all engines must meet specific Audi quality standards. Preferred viscosity (weight) for all engines is SAE 5W40. Do not overfill."
Old Jan 9, 2008 | 09:51 PM
cincyTT's Avatar
I'm make believe
it helps seat the rings better. Syn is way to slick for them to do this properly.
Old Jan 9, 2008 | 09:55 PM
beachchair's Avatar
ORIGINAL: cincyTT
That makes sense. Good info. Thanks
