Defcon 1 or Front sway bar
Old Dec 20, 2008 | 03:29 PM
TTLayne's Avatar
Member
Default Defcon 1 or Front sway bar
I don’t know whether or to get the Defcon 1 or an 25mm H+R front sway bar. I already have the rear and I’m eventually going to do both mods in time but which mod will bring me the best handling results because I plan on going up to deals gap in the spring.
Thanks Layne
Old Dec 20, 2008 | 05:03 PM
MCPaudiTT's Avatar
If you do a front bar, you should increase your rear bar even more (above 19mm), or adjust it to stiffer if you have an adjustable one. DEFCONs will work great with or without an ARB change, and will improve handling.
If you are dead-set on an ARB change, though, you should do them both at the same time to save costs. You will need an alignment with both the DEFCON and the front bar, as both will require it. If you do them together, it will only be one alignment cost. If you do them separately, it will take two alignments...
randomloginname
Apr 9, 2008 06:21 PM
wood_e
Mar 25, 2008 08:12 AM
B5luver
Dec 18, 2007 12:42 AM
duburban
May 1, 2007 03:07 PM
theguy1084
Feb 6, 2007 09:28 PM
