Did N249 delete, couple q's
Old Feb 10, 2009 | 10:17 PM
AWDrifter's Avatar
Default Did N249 delete, couple q's
I did the N249 delete and it was pretty straight forward. Got a couple questions regaurding some more clean up...
The charge pipe is aluminum right? I want to weld up the hole where my DV used to vent to so I dont have a little piece of hose and crap.
In the pic, the black thing connects the 2 breather ports to the tip. So this can be removed and a CC goes there?
And whats the thing circled? Assuming something for the sai cause its connected to the N112(?) mounted under the plate bolted to the mani.
Thanks.
Old Feb 10, 2009 | 10:28 PM
cincyTT's Avatar
I'm make believe
Yes on all counts. The egr will be removed with a sai block off plate. You can get them from 20squared.com (you may need to get it from the mkiv section)
Old Feb 10, 2009 | 10:56 PM
AWDrifter's Avatar
Sorry, egr? Is that the circled part? Is there a cel associated with removing it?
Old Feb 11, 2009 | 10:50 AM
cincyTT's Avatar
I'm make believe
Exhaust gas recir. Its actually called the Combi valve. You will get a cel, you need a resistor from 20squared to stop it or a chip with it written out
Old Feb 11, 2009 | 06:04 PM
AWDrifter's Avatar
I have another resistor, same as from the N249 right? I thought you still got an improper flow cel which is why it only works to have it written out?
Old Feb 11, 2009 | 06:27 PM
achTTung's Avatar
NOT right on all counts.
The charge pipe IS NOT aluminum.
And its secondary air injection, not exhaust gas recirculation.
Also, I'll sell you a SAI blockoff plate for $20 shipped. Stainless steel, no o-ring groove like the fancy ones you see online for $70, but if you reuse the steel washer from the stock piece with a little high temp gasket goop, it works fine. PM me if your interested.
$70 for a walnut sized piece of aluminum is insane.
Old Feb 11, 2009 | 06:45 PM
AWDrifter's Avatar
Well I will find out what the charge pipe is as soon as I pull it to weld it I was just curious. And I think I am going to leave sai in for now.
Old Feb 11, 2009 | 07:43 PM
achTTung's Avatar
Its stainless, haven't looked close enough to see which grade.
If you change your mind on the SAI at some point, let me know, offer stands. Take me a day to cut it, deburr the edges, and put a brushed finish on it. Otherwise, should be quick to ship.
Old Feb 11, 2009 | 08:05 PM
AWDrifter's Avatar
Alright thanks, Ill let you know if I do. Im curious how it knows if there is "improper flow" All it does is pump air from the air box to the exhuast side of the head right? If you replace the N112 and sai pump with resistors, where is the sensor that knows if there is air being pumped (or lack thereof)
Old Feb 11, 2009 | 08:23 PM
achTTung's Avatar
I wish I knew. I've thought about that myself. Possibly O2 sensor?
jhsoccerodp
Nov 1, 2021 08:03 PM
nickelectron
Jun 15, 2010 06:09 PM
whitejeepXJ
Oct 29, 2009 12:21 AM
l88m22vette
Oct 2, 2008 05:06 PM
MeanAudiA6
Apr 7, 2008 06:03 PM
