Diode Mod, Boost Guage, and MBC Install
  #21
Old 04-06-2007, 09:43 PM
ooantipostoo's Avatar
Default RE: Diode Mod, Boost Guage, and MBC Install
I wasnt trying to be rude at all. Just wondering how do you know the air/fuel ratio?
  #22
Old 04-06-2007, 10:12 PM
cincyTT's Avatar
I'm make believe
im well within check, ill show you my plugs if you want.
  #23
Old 04-06-2007, 10:23 PM
I was just curious, i showed the mod to my friend that owns a shop and he said it would be dangerous. He said that they came out with some thing along the same line for RX-7's but its not increasing the boost its increasing the air fuel ratio. I just thought it would do the same thing with the Audi because the ECU would be requesting more gas and such but it would only still be seeing the stock 11psi wouldnt it contradict it self?
  #24
Old 04-06-2007, 10:41 PM
cincyTT's Avatar
I'm make believe
the me7 ecu is a very intellegent system, often to smart for most tuners. It will adapt to the extra air with extra fuel within a certain range. And its the extra air you have to account for, not fuel. Like i have said before in this thread and in others, "i have run this for over a year now and have had no problems." You can tell your friend to do some more research on audi/vw before giving uninformed advise.
  #25
Old 04-07-2007, 08:07 PM
Babz's Avatar
Hey cincytt , ive searched but havent found much. Do yo know if the mbc and diode mod can be done on a 1997 Audi A4 1.8Tqm??? If so how do i go about it?? Any help would be appreciated.. THanx
  #26
Old 04-07-2007, 08:09 PM
cincyTT's Avatar
I'm make believe
you need to have a map car. the first a4 is the 2000-2001.
  #27
Old 04-07-2007, 08:14 PM
Babz's Avatar
Meaning it will not work on a car that has MAF?? Cool . thanx for the help. Gues i got to get a chip after all or be standard until i go BT.
  #28
Old 04-07-2007, 08:34 PM
cincyTT's Avatar
I'm make believe
All the 1.8t's have a MAF, you need a MAP also, in the later carstheMAPis what tells the ecu how many psi you are running.
  #29
Old 04-08-2007, 10:25 PM
Sick i just picked up a greddy profec A for the boost controller / guage now all i need is a diode and im trying this out. The profec A will work well with this right?
  #30
Old 04-08-2007, 11:17 PM
cincyTT's Avatar
I'm make believe
any boost controller will work.
Quick Reply: Diode Mod, Boost Guage, and MBC Install
