DIY Clutch Replacment Questions
Old Jan 27, 2008 | 02:46 PM
Red_sapphire89's Avatar
Default DIY Clutch Replacment Questions
I have decided enough is enough I am doing everything my self from this point forward! Anyways I am trying to compose a rought estimate of what I need to do the job Here is what I have so far those with expirience please help add to the list.
Bentley Audi tt service manual
2 tall jack stands 48in
floor jack
transmission jack
clutch alignment tool
torque wrench
sockets wrenches pliers screw drivers etc
pry bar
clutch and fly wheel and master cylinder
misc fluids
loctite
Are there any specialty tools i may need? Like uncommon ones?
Old Jan 27, 2008 | 03:03 PM
MeanAudiA6's Avatar
Default RE: DIY Clutch Replacment Questions
i would get another 2 jack stands to make the car even....wouldnt do just the front...you want the car to be as level as possible so the tranny will go in smooth...and when you align the clutch make sure you can smoothly move the tool in and out a few times to make sure its correctly lined up. also there is a metal gasket between the engine and the actual bell housing of the tranny...make sure to get it back in there...it has bolt holes that the gasket goes on to help this. looks like you pretty much got everything except a bleeder for the clutch...i uses a handheld pump with a collector bottle and a vac line to get the fluid out of the clutch fluid line. OHH and the biggest thing here....when you disconnect the main drive shaft DO NOT damage the seal inside...also you will need to cut the end off(leave the shaft) a open ended wrench 9mm and put it into a breaker bar to get the bolts loose on the main driveshaft. so have something that can cut metal wrenches. i think thats the only tool i had to make to do this. you will also have to disconnect your cat back from the cat...you dont have to remove the whole exhaust so just tie it up and make sure not to move it around too much or you can damage your cat converters joints(flex section)
Old Jan 27, 2008 | 03:12 PM
I just realized your in indiana where abouts i am in ft.wayne and indianapolis
Old Jan 27, 2008 | 03:14 PM
MeanAudiA6's Avatar
im in fort wayne well huntertown but its just a mile away from ft wayne
Old Jan 27, 2008 | 03:19 PM
=) I got to go to work but....=) =)
Old Jan 27, 2008 | 03:28 PM
MeanAudiA6's Avatar
haha...idk man not really something i ever wanna do again thats forsure. could use the money but i work and go to school full time. could maybe get it done in a two or three days
Old Jan 28, 2008 | 11:55 AM
Nah i want to do it myself but i dont wanna spend cash on bs stuff aha maybe you could rent me your jack stands and stuff for a week?
Old Jan 28, 2008 | 12:35 PM
WishIWasRWD's Avatar
Can Anyoneget mea printout of the manual?
Old Jan 30, 2008 | 06:05 PM
Can i use a regular jack to lower the tranny to the ground?
Old Jan 30, 2008 | 06:36 PM
jakej's Avatar
cool... 48inch jack stands?? Can you really jack the car up a few feet??
