Does anybody know of this Product?
its from Apexi and is called I-Moni OBD II Monitoring Device eurostyleseast.com basically plugs into the diagnostic port and gives you ENGINE RPM< WATER TEMP<INTAKE AIR TEMP<AND VEHICLE SPEED IN REAL TIME!!! i think i'll be buying it soon and just wanted to know if anyone has it or knows anything about it? I think its a great tool and can give you early warning if stuff goes wrong
That is basically a diagnostic device something like the dealers use. I bought the Ross Tech vag com and it does a bit more. If Im right the OBD only sees the engine code readings but the Ross Tech vag com sees those and more. Plus you can do live monitoring, recording and some changing with the Ross Tech. I would check out both and compare them to make sure you get what you want.
ya i know this but the i-moni is somthing that u can mount on the dash and get this readings in real time! u dont have to have a laptop hooked up to it.
