down on power??..
Old Jan 11, 2009 | 06:08 PM
warranty225cpe's Avatar
Default down on power??..
So. I just replaced my TIP. And for some reason, it feels like the power isnt there. Im not sure if I missed something? or if one of the hoses has a slit or crack in it??.. With the liquid TT running, im missing about 10-15hp and 15-25TQ.. any suggestions?
Old Jan 11, 2009 | 06:39 PM
cincyTT's Avatar
I'm make believe
check all or your connections and reset the ecu
Old Jan 11, 2009 | 06:59 PM
And I reset by disconnecting the bat.?
Old Jan 11, 2009 | 07:14 PM
cincyTT's Avatar
I'm make believe
thats on way, yes
Old Jan 11, 2009 | 07:18 PM
how long would I have to leave the bat. Disco.? Or should I do it a different/easier way?
Old Jan 11, 2009 | 07:24 PM
cincyTT's Avatar
I'm make believe
It will take 5-10mins to reset. The other way is with a code reader or vagcom
Old Jan 11, 2009 | 07:30 PM
Cool thanks. I'm thinking maybe the end that connects to the turbo might not be on all the way.
Old Jan 11, 2009 | 07:46 PM
cincyTT's Avatar
I'm make believe
That would screw up the maf readings. My tip came loose and i thought i had a dead maf. Ran it unpluged for about a month waiting on a new maf and replaced it and no change. If you unplug the maf and you gain power, deff a intake leak
Old Jan 11, 2009 | 07:50 PM
Unplug the MAF? Or pull it all together?
Old Jan 11, 2009 | 08:03 PM
Would my maf(or any other liquid TT readings)give me an indication of intake leak?
