Dyno sheets?
Old Jun 14, 2007 | 04:26 AM
Anos's Avatar
Default Dyno sheets?
By chance, do any of you have your Dyno Sheets posted anywhere? Im curious to know what a Bone Stock 2000 Audi TT 180 Quattro has for HP/TQ to the wheels. None of that to the crank garbage. I've been trying to locate an AWD dyno around my area and sooo far nooo luck (weak). Im curious for numbers since I have been looking at AWE's GIAC chip for my car. And would like to know what the these cars start out at stock. Im guessing with a ~18% Drive train loss the 180 would be ~147.6HP and ~108ft-lbs.
If the giac can "Guarantee" atleast +23hp (170hp to the wheels) and plus a Staggering +85ft-lbs of torque (193ft-lbs to the wheels) Just from the chip, then I will be dropping the money ASAP to get it. But im a "if i see it, ill beleive it" type of person and am slowly becoming more dependent on numbers to lead my way.
I'm assuming those numbers are with the turbo's boost set to OEM standards as well. If that's true, this should have been my very first upgrade lol. Thanks for any help =)
Old Jun 14, 2007 | 11:57 AM
cincyTT's Avatar
I'm make believe
Default RE: Dyno sheets?
1.8t dyno sheets
the stock numbers are 180hp and 170ftlbs. with a chip you should be in the 170awhp range and about 210-220ftlbs.
Old Jun 14, 2007 | 04:36 PM
Anos's Avatar
hmmm...that is a very substantial gain from Just the chip alone. Borla claims also their exhaust can add upto +15hp/tq after it's 700-800mile break in time frame. Would be cool if that gain is also true. Hmmm guess i'll give AWE a call and ask some questions about the chip and pick one up if alls good.
Old Jun 14, 2007 | 04:58 PM
cincyTT's Avatar
I'm make believe
your increasingboost pressure 7-10psi, what did you expect? Also going from a 2" exhaust to a 2/5" or 3" is going to make a rather big improvement on letting the turbo exhale.
Old Jun 14, 2007 | 05:18 PM
Anos's Avatar
Yea I just found out about the boost increase lol. I just got off the phone with one of their techs and he explained it all to me. Very cool guy. I wasnt sure if the chip was increasing the boost or what it would be doing (first car i've ever read about chipping). He also brought to my attention on of their DV's (Bailey Motorsports) and recommends it since it's self tuning, and they use it in everycar that comes through. *shrug* maybe ill sell my Forge and give theirs a shot and see how it goes. Any one here using the Bailey Motorsports DV?
I should try to open this exhaust up a little more then, the Borla im sure is a good start, ill hunt around for a high flow cat for my car.
Old Jun 14, 2007 | 07:19 PM
cincyTT's Avatar
I'm make believe
dont waste your money on a new dv. both will function exactly the same and will last longer than the car. they tell you that to increase the sale, much like a normal shop.
But yes, chip increase both boost and some timing.
turbo kraut
Apr 2, 2008 12:15 PM
tcr20
Jun 27, 2007 03:36 PM
BaconBait
Feb 23, 2007 11:56 AM
SooprmanX
Jun 27, 2005 04:24 PM
SrK
Jun 22, 2005 01:04 PM
