:: ECS Tuning :: MKI TT Wheel Adapter Kits - 5x100 to 5x114.3
Have your eyes on the perfect set of wheels for your 5x100 bolt-pattern AUDI MKI TT, only to realize they won't bolt up?
ECS Tuning bolt-on wheel adapter kits open up an entire new world of wheel styles and fitments. Precision machined from heat-treated aluminum with threaded steel inserts, these hubcentric adapters bolt to your 5x100 57.1mm wheel hub, effectively making it a 5x114.3 hub.
These durable, anodized adapters come in a kit with all the required hardware. Bolt them on and get exactly the set of wheels your stock bolt pattern has been denying you.
Advantages:
- Bolt-to-hub design makes wheel changes faster and easier.
- Hubcentric for a true, vibration-free mount.
- Lightweight aluminum keeps unsprung weight low.
- Black anodized for hardness and corrosion resistance.
- Chrome mounting bolts, 10.9 hardness.
- Press fit, steel threaded inserts for added strength.
- CNC machined to exacting tolerances.
- Ideal for adding wheel clearance on cars with oversized brakes.
- 20, 22.5, 25, 27.5, 30mm sizes available.
- CAD designed and manufactured at an ISO 9001 certified facility.
Want new wheels? Adapt.
Click HERE to order or for more information
Fits:
AUDI MKI TT (1998 - 2006)
Check out our installation PDF HERE
Let me know if you have any questions.
Jason
ECS Tuning
Oct 14, 2013 05:08 PM
ECS Tuning
Aug 16, 2013 05:07 PM
ECS Tuning
Aug 16, 2013 05:06 PM
