:: ECS Tuning :: NEW ITEM Front 2-Piece Brake Rotors For MKI TT 3.2L!!
Old Jan 30, 2014 | 01:55 PM
ECS Tuning's Avatar
Sponsor
Default :: ECS Tuning :: NEW ITEM Front 2-Piece Brake Rotors For MKI TT 3.2L!!
ECS Tuning proudly introduces our new 2-Piece brake rotors for MKI Audi TT 3.2L. Reduce weight. Reduce heat. Reduce warping.
ECS engineered 2-Piece semi-floating rotors offer real world benefits that can be felt on both the street and track!
Our 2-Piece rotors combine the advantages of weight savings and rapid heat dissipation to provide a rotor superior to stock while preventing warping and extending component life.
The reduction of unsprung weight improves handling characteristics under all situations. This reduction in rotational inertia allows for quicker acceleration, decreased braking distances, and more responsive handling.
Features include:
  • Aluminum hats: To save weight, each rotor ring is bolted to a lightweight aluminum hat made from high quality 6061 aluminum, and hard anodized with an attractive matte black finish that is both durable and corrosion resistant.
  • Gray cast iron rings: Long known for its wear resistance and stable friction characteristics, cast iron is favored for brake rotors due to its ability to absorb and dissipate large amounts of heat.
  • 2-Piece construction: Conventional rotors are unable to cope with the stress of drastic heat fluctuations and are prone to warping. ECS 2-Piece semi-floating rotors allow the radial expansion of the rotor ring - preventing warping.
  • Heat treated: Heat treating further reduces the tendency for rotor cracking by reducing internal rotor stresses.
  • Directionally veined: Conventional R32/TT rotors are straight-veined, and rely on an inefficient centrifuge-like effect to evacuate hot air from within the rotor. ECS 2-Piece rotors feature curved, directional veins that accelerate air away from the rotor at a higher velocity, leading to consistent, rapid cooling.
  • Drilled and slotted: 2-Piece rotors are cross drilled to promote cross ventilation for improved cooling as well as slotted to clean brake pads and carry away water and brake dust. Cleaner brake pads result in faster, more consistent stopping. Drilled holes are chamfered while slots are machined with a ball end mill - both to prevent cracking that may be present on improperly machined rotors.
  • Overall weight savings: This particular ECS 2-Piece rotor weighs only 19.6 lbs compared to a stock R32/TT rotor at 23 lbs. Lighter rotors reduce unsprung weight and rotational mass to improve both braking and suspension performance.
  • Manufacturing quality: Non-friction ring surfaces, including internal vents, are painted to resist salt and other corrosives. Ground braking surfaces ensure rings run parallel, and pads bed easily.
Stopping Never Looked So Good
Click HERE to order or for more information
Fits:
Make(s): Audi
Model(s): TT
Submodel(s): 3.2L
Year(s): 2003-2006
Chassis: MKI
Ready for a replacement set of rotors? ECS offers discounts on pairs of replacement rotors to the original customer or customers showing proof of ownership. Please contact the Sales Department for additional information.
Let me know if you have any questions.
Jason
ECS Tuning
RS4
Feb 19, 2015 03:31 PM
ECS Tuning
S4
Sep 25, 2014 01:02 PM
ECS Tuning
Jan 30, 2014 01:56 PM
ECS Tuning
Apr 11, 2013 11:10 AM
ECS Tuning
Apr 11, 2013 11:07 AM
