:: ECS Tuning :: Timing Belt Kits - MK1 Audi TT
Old Feb 20, 2014 | 04:05 PM
ECS Tuning's Avatar
Sponsor
Default :: ECS Tuning :: Timing Belt Kits - MK1 Audi TT
A broken timing belt does more than leave you in tennis shoe mode; it causes extensive and expensive engine damage when piston heads contact the valves and mangle the head.
Don't wait for disaster to strike. Check out our wide assortment of timing belt kits. We have you covered: from standard belt-tensioner combos to ultimate kits with water pump, thermostat, accessory belts, bolts, and seals.
Looking for some extra performance? We offer complete kits including Gates Racing belts, underdrive pulleys, and lightweight crank pulleys.
ECS: We have what you need to get it done.
Standard
  • Timing Belt
  • Tensioner
  • Tensioner Roller
Ultimate
  • Timing Belt
  • Tensioner Roller
  • Tensioner Assembly
  • Idler Roller
  • Water Pump With Metal Impeller
  • Accessory Drive Belt
  • Thermostat
  • Thermostat Housing
  • Engine Mount Bolt Kit (7pc)
  • Camshaft Seal
  • Crankshaft Seal
Ulitmate Plus
  • Timing Belt
  • Tensioner Roller
  • Idler Roller
  • Water Pump (Featuring a metal impeller)
  • Thermostat
  • Engine mount Bolt Set (7pc)
  • Camshaft Seal
  • Crankshaft Seal
  • 1.5 Liter Bottle of G13 Coolant - Two
Timing is Everything
Click HERE to order or for more information
Fits:
MK1 Audi TT (2000-2006) 180hp / 225hp
Let me know if you have any questions
Jason
ECS Tuning
S4
Aug 20, 2015 02:50 PM
ECS Tuning
Aug 19, 2015 05:12 PM
ECS Tuning
Jul 31, 2014 07:48 AM
ECS Tuning
Feb 20, 2014 04:06 PM
ECS Tuning
Aug 2, 2012 03:40 PM
