I'm not sure if these problems are at all related, but it seems in the last 2 months I've had more than I can imagine. Started off with the car stalling out while driving. This ended up being the crank position sensor. Got that replaced and now there have been all sorts of what seems to be electrical issues with the car. First I noticed the cruise control not working. Then the hazard relay went bad. Now the AC has quit (compressor on order), and today the EPS light came on while I was driving. I tracked it down to a blown brake light fuse, but it keeps blowing everytime I replace it. And NOT when I step on the brakes, but after I start driving. I replace the fuse, brake lights work, drive and at about 10 MPH the EPS light comes back on and the fuse has blown. That seems like an awful lot of mishaps all since I replaced the crank sensor???? Can ANYONE help me out?
Tags
audi, aui, brake, car, control, crankshaft, cruise, eps, esp, flashes, indicator, light, position, sensor, tt
- left rear running light does not work nor the gauge cluster light at the same time?
- 01 a6 quattro 2.7T Tail light, fog light, and side marker light question.
- B5 Audi a4 High mount brake light (third bake light), light replacement???
- Check Engine Light, ESP Light, And EPC Light
- Check Engine Light & ABS Light and Flashing Brake Light
