Experience with HID upgrade?
Old May 28, 2007 | 01:06 AM
neur0tic's Avatar
Default Experience with HID upgrade?
curious if anyone here has any experience with HID upgrades.
I stopped by a a custom Car A/V shop yesterday here in Korea and saw some 12k HIDs.
I see they have the 10k upgrade on the ECStuning site, are these just plug and play or is there a new power supply and/or converter of some kind needed to run these as opposed to the stock 4300 HIDs?
Btw... Im in Korea, but curious if anyone knows the street legal limit in the US for HID intensity. Is it 6k?
Old May 28, 2007 | 02:47 AM
ouTTie914's Avatar
Default RE: Experience with HID upgrade?
Not so sure why you want brighter headlights, but it seems 6k and higher are for off road use exclusively.
I've only heard of HID conversion kits for cars that have normal headlights.
I'm going to assume that you would just plug them in. Considering our cars already have a HID ignitor and relay.
This is the only federal document I could find, Clicky
State laws
Old May 28, 2007 | 12:03 PM
cincyTT's Avatar
I'm make believe
stock is in the 6k range. You go lower to 3k, they will be yellow, and if you go up to about 8k they will be blue and 12k will be purple. You now have the cleanest and brightest. So if you change you will lower the lights brightness and just be changing the color.
Old May 28, 2007 | 12:19 PM
jcll2002's Avatar
im pretty sure stock is 4300k
Old May 28, 2007 | 12:41 PM
cincyTT's Avatar
I'm make believe
**edited, 3000k is yellow,you may be right since there really isnt that much blue likeon aBMW.
Old May 28, 2007 | 03:07 PM
theTTkid's Avatar
legal = 8k in us i believe
Old May 29, 2007 | 04:46 PM
NeXeA500's Avatar
k stands for kelvin temperature of the lighting. The higher the kelvins (k) the more colorful the light, but you tend to lose some brigtness. I was thinking about using 8k hid's instead of the stock 4300k. All you have to do is find the bulb fitting size, i want to say its h1 or h2... not sure, i couldnt really find this answer... maybe do a forum search... but all you have to do is plug them into the stock ballasts. Very easy... if you can get the fixtures out, which i beleive you need to remove the front bumper? Not sure though. Good luck!
Old May 29, 2007 | 10:59 PM
cincyTT's Avatar
I'm make believe
i still dont know why he wants purple lights with his green car, kindagross if you ask me.
Old May 30, 2007 | 02:09 PM
TSRgeneral's Avatar
I would only change the Fogs to match my HID's. That would be hot ! I bought some normal blubs for my fogs and fot the colour pretty close. Pictures to come
Old May 30, 2007 | 03:32 PM
neur0tic's Avatar
yea good call... I didn't realize that the color changed that drastically with it. I'll probably only go as high as 6-8k if I choose to upgrade. I like the lights I currently have, but I do consider them a bright yellowish. I'd prefer white or even a faint bluish tint (more white than blue) over the yellow.
