Factory Navigation Hookup?
Old 08-14-2007, 01:16 PM
Jaguar77's Avatar
Default Factory Navigation Hookup?
Pardon my ignorance, I have done a bunch of searching but haven't found a concreate answer.
I have a 2001 TT Roadster and noticed that in the back right compartment in the well, there is a 20 pin serial cable. I assume it is there for the optional factory nav unit. Is this correct? If so, all roadsters are pre wired for factory nav? I looked at some pics of the unit itself and didn't see any cables that looked like a normal 20 pin serial, so I am confused. Thanks!
Old 08-14-2007, 01:29 PM
ouTTie914's Avatar
Default RE: Factory Navigation Hookup?
There are a lot of compartments are you talking about inside the cab, or in the trunk?
Old 08-14-2007, 01:31 PM
Jaguar77's Avatar
Inside the cab, in the well where the top folds into. There are 2 covers that lift up. This plug is under the cover on the passenger side. Thanks.
Old 08-14-2007, 01:43 PM
ouTTie914's Avatar
Not sure about the pass. side the nav hookup is on the driver's side, but it would be where the top folds up.
Check this out for a better understanding, just register to see the image. Clicky!
Old 08-14-2007, 01:51 PM
Jaguar77's Avatar
Thanks for the link, I've seen that pic but it doesn't really help me. I'm thinking that this compartment and serial cable are where the actual navigation drive (number 3 in your pic link) goes (there is also a bracket in there to hold something). But I'm still confused about the 20 pin serial as the pics of the nav drives don't seem to have a serial connection. Surely someone else has noticed an extra serial cable that doesn't do anything hidden in their car.
Old 08-14-2007, 01:54 PM
ouTTie914's Avatar
The only other thing I can think of is the OBD port... but that's usually under the headlight switch.
Unless roadsters are backwards like that...
Old 08-14-2007, 02:40 PM
Jaguar77's Avatar
Upon further inspection, it is a 25 pin, not 20, female serial cable. There is also a wire with a coax connetor on it. I assume this is the gps antenna. I'm curious if all '01 roadsters are pre wired like this, and if so, can a nav unit just be dropped in there and the controls added to the center console?
Old 08-16-2007, 12:23 AM
Jaguar77's Avatar
*bump*
I still haven't figured this one out. Possibly something for the in car phone system? I've looked through the audi repair manual and still can't find an answer.....
Old 08-16-2007, 01:10 AM
Murderface's Avatar
Since 90% of the people here are coupe guys...I think he's talking about the serial cable that (on a coupe) would be in the little door in the left wall of the hatch that you'd use to access headlight wiring. I saw it there while doing an Audio install, was kinda curious what it was for myself.
Factory nav adds a little console in the middle next to the ebrake (where your unlock/lock button and top/glass up/down button are) so I don't think that they're entirely "pre wired."
Old 08-16-2007, 09:18 AM
alan93's Avatar
ORIGINAL: Jaguar77
The navigation unit is on the passenger side for the roadster.
I've never taken mine out so I can't verify the connection and I don't have my bentley manual with me here.
Quick Reply: Factory Navigation Hookup?
