Fault code p1340
Fault code p1340
Hey people I just got this 2000Audi TT quattro 2 days ago with the check engine light on and today when I went to smog check it the car passed everything but the engine light....The code that came up is p1340 camshaft position sensor or something like that, my question is have any of you delt with or heard of this problem before?
RE: Fault code p1340
ORIGINAL: martinezadamjbd
Crankshaft-/Camshaft Pos. Sens. Signals Out of Sequence.
out of sequence my data says ( is it lose? is the wiring ok and the connector plugged in tight ) I had that problem with a vauxhall omega[:@]because it was an inline engine and the cam sensor was on the front of the engine and above the rocker cover so every time I leaned over the engineer it upset the cables
