Faulty Fuel Gauge - - ;;
Old Jan 19, 2008 | 02:08 AM
VaTTer's Avatar
Member
Default Faulty Fuel Gauge - - ;;
Im guessing this is an instrumental cluster problem, because my fuel gauge is WroNG. it keeps saying that I have full gas but I dont... what is up? Is there a simple fix for this besided getting a new cluster?
Old Jan 19, 2008 | 08:07 AM
achTTung's Avatar
Default RE: Faulty Fuel Gauge - - ;;
Maybe.
Could be that your senders are dirty, you can either run a few tanks of some sort of fuel line cleaner thru, or pull the senders, and manually clean them.
Old Jan 19, 2008 | 02:03 PM
VaTTer's Avatar
Member
do you know what causes the senders to be dirty? is it just natural build up
Old Jan 19, 2008 | 02:19 PM
cincyTT's Avatar
I'm make believe
not sure the cause, but cleaning the senders would be a good place to start
Old Jan 19, 2008 | 03:24 PM
timbo108's Avatar
Maybe try adding some Chevron Techron to the fuel tank ? It helped when my gauge was slow to rise....must break up some gunk on the sender.
Old Jan 20, 2008 | 03:36 AM
cspinner's Avatar
Search for threads started by me. I had the same exact problem. I followed a DIY to clean the senders and it seemed to fix things... I cleaned one out of two, but maybe I shouldve done both...
Old Jan 20, 2008 | 05:03 PM
VaTTer's Avatar
Member
Do you happen to have the diy for the senders ...
for some reason yesterday it was fine ... (i think it is the cold weather that is making my car go crazy)
Old Jan 20, 2008 | 08:18 PM
cspinner's Avatar
Here you go. http://public.fotki.com/RoberTT/main...g_fuel_sender/
TAKE YOUR TIME. The last thing you need is to tear your lines.
Old Jan 21, 2008 | 12:00 AM
auditech79's Avatar
If you have a VAG COM you can eliminate the cluster being bad in about 5 minutes by doing a gauge sweep. Go to module 17 and select output diagnostics and the gauges should all sweep together, if the gas gauge wacks out, you know its a cluster problem.
Old Jan 21, 2008 | 03:59 AM
VaTTer's Avatar
Member
ORIGINAL: cspinner
NICE~ thanks man ... yea im not really good with figuring where everything goes so diy w/ pix
is what i needed.
