A few Questions
Old May 17, 2008 | 11:37 AM
BreezeThe TT's Avatar
Default A few Questions
1. I Need To KNow Where I Can Get A Good and Cheap upgraded ECU For My 1.8 TT?
2. Where I Can Get Upgraded Fuel Pump and Fuel Return Line?
3. What Is The Lower Rear Panel Called That The Exhaust Comes Out Of? Because I Need To Get Another Dual One?
Old May 17, 2008 | 12:28 PM
randomloginname's Avatar
Default RE: A few Questions
good and cheap do not go together. do you need a new ecu because somethigns wrong with yours or are you just looking for a software upgrade. for the love of god read the faq. goapr has an upgraded fuel pump, but its going to depend wheter you have quattro or not, use the search feature. the exhaust valence, there are two aftermarket options that i can think of, one is the oem 3.2 rear honeycomb valence, the other is the osir dtm valence. tt shop (uk) site has a few more likely. check http://ttstuff.com/accessories_styling_main.phpfor the prior 2
Old May 17, 2008 | 04:05 PM
cincyTT's Avatar
I'm make believe
there is not point in changing the fuel pump unless you are running 300whp or more. The fuel lines are good for over 500whp
mblayton
Jan 7, 2010 07:35 PM
playboy00786
May 31, 2008 06:37 PM
zchb9
May 20, 2006 01:29 PM
portwolf
May 18, 2006 03:27 PM
VolcanicBlackA4
May 18, 2006 02:11 PM
