front mount intercooler
Old Feb 25, 2007 | 10:56 PM
sheepcan's Avatar
Default front mount intercooler
Does anyone have one, do they add power, ordoes it just keep it cooler.
Old Feb 26, 2007 | 12:19 AM
diehlryan's Avatar
Default RE: front mount intercooler
lets see if I'm learned enough in the last few months.
FMIC do notadd horsepower. They help keep the power you have by limiting power loss due to heat.
Old Feb 26, 2007 | 12:24 AM
sheepcan's Avatar
thats what i was thinking i just didn't know, they are expensive sothey must work pretty good
Old Feb 26, 2007 | 11:31 AM
225tt's Avatar
Steve S. did a test on his forge mesuring the intake temp before and after the intercooler and calculated that the Forge FMIC runs about 90% efficency. The dual SMIC on the 225 run about 80% max. Its on his fokti page. Check it out.
Old Feb 26, 2007 | 02:31 PM
MeanAudiA6's Avatar
yup and APR is more effective at cooling than that....bcuz of the design of the end tanks and core....they also claim the plumbing is better than everyone elses.
Old Feb 26, 2007 | 03:07 PM
225tt's Avatar
They also state that theres is the most expensive lol, but I guess for HP you gota have $$$$
Old Feb 26, 2007 | 03:30 PM
TTsteve's Avatar
I have the 180 TT with a bigger turbo and just on smic was robbing me of alot of hp plus heating the whole engine up. I put an APR FMIC on and it really keeps the temp down giving back all that lost hp due to the intake air being so hot, which means less air and less power. It was a good bit of dollars but well worth it when you are doing a lot of mods.
Old Feb 26, 2007 | 03:49 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: MeanAudiA6
The forge one was more around low 90% (92-94%) I can't imagine apr's to be much higher/more gains than that unless your using a gt35r @ no more than 10psi. You can only lower an air to air ic so far and anything in the 90% range isa good core.
Old Feb 26, 2007 | 06:41 PM
225tt's Avatar
Yea I would die to get into the 90% range, well maybe one of these days, and ideas of what TCarbons FMIC runs?
Old Feb 26, 2007 | 06:49 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: 225tt
No idea, but im not sure if you have seen this thread yet. http://forums.vwvortex.com/zerothread?id=3067990
He is still waiting delievery and is will to post picks of the ic (close up front and inside also) for people. After visual a good guess could be made.
