fuel door and trunk lid not working
Old May 24, 2009 | 09:43 AM
ret's Avatar
ret
I'm not sure if this is the same problem I was having. However, about a year ago I had the same random electrical issues. It turns out that the battery connectors were loose. You might want to check them out.
Old Jul 28, 2021 | 10:15 AM
wolfgang51's Avatar
2002 TT convertible, I had the car at a detail shop and got it back and things seem not to work. the trunk and gas lids are not operating and the door lock process does not make the beep sound and the small red light on the door does not go on. I checked a couple of fuses and found them all OK. I am at a loss. They all worked fine before getting the car cleaned. I am a loss.
Old Apr 3, 2023 | 04:56 PM
leahwarner68's Avatar
Default Amazing!
Originally Posted by 2Screwed
Had the same thing happen to me. Stick the key in the driver door, lock and unlock several times then try again. Worked for me. Think it has something to do with the door lock mechanism control thing-a-ma-gig, but it works.
thank you so much for this information! I had tried everything and nothing worked until I read your suggestion and tried that and it worked!!! Crazy but thank you
Old May 15, 2023 | 01:35 PM
Gareth399's Avatar
Default God send
Worked a treat, loosing my **** in a petrol station looking for a fuse, calmed down had a quick Google and this worked perfectly. Ivwas very close to using a screwdriver to open it.
Old Jan 10, 2025 | 04:26 PM
bobdabuilder's Avatar
Question No Luck here either.
After replacing a very dead battery with a new one I was able to get almost everything working accept the gas cap and trunk release. Has anyone found a 'FUSE' that makes a difference? Does it help to reset the radio code again? Mine is a 2004 roadster if it makes a difference.
Oddy Ay Fore
Aug 23, 2012 03:39 PM
Bastid
Jul 3, 2010 05:48 PM
Bastid
Jul 3, 2010 05:24 PM
cukilo
Mar 28, 2009 11:14 AM
baal2005
Mar 16, 2006 01:18 PM
