Got a CEL last night
Old Aug 12, 2008 | 11:38 AM
gibson 01's Avatar
Thumbs down Got a CEL last night
My car was doing fine until i got on the gas and when it reached 5500 rpm it bogged down and started running like s**t. I dont know what limp mode feels like but thats what i would say it is. My car sputters and shakes when i drive it know. I got chipped a couple of months ago. APR flash 93 octane, (couldnt tell much difference?) I need a Boost gauge! I did replace my DV (forge007). Im going to get the CEL read and i will come back with a code.
I got a 2001 180fwd.
Old Aug 12, 2008 | 11:43 AM
cincyTT's Avatar
I'm make believe
You had misfires. Make sure your plugs are gapped down to .028 with a chip
Old Aug 12, 2008 | 01:09 PM
gibson 01's Avatar
Ok, just got back from auto store and the CEL was: random misfire in 1 & 2. I did change my plugs to NGK BKR7E .028 gap when i got chipped. My boots are coming up off of my plugs maybe a 1/2". I pushed them back down and it still doesnt run right. I am going to pull my plugs and see what they look like now.
Old Aug 12, 2008 | 01:25 PM
cincyTT's Avatar
I'm make believe
them not being torqued right will cause the coil packs to lift and that can cause the misfire.
Old Aug 12, 2008 | 06:03 PM
gibson 01's Avatar
Question
I checked my sparkplugs, they are fine. They're maybe a month old. I torqed them down to 20 lbs. The coil packs are not coming up any more, but its still running like crap. Do i need to get the code cleared before it starts running right? Or unplug the battery over night and let the engine reset?
Old Aug 12, 2008 | 07:00 PM
cincyTT's Avatar
I'm make believe
Get the code scanned and it will tell you what threw it. Then you can just reset the ecu by unplugging it for ~10mins
.clipse's Avatar
SoCal Crew Member
try swapping the coilpacks?
Old Aug 13, 2008 | 12:16 AM
XCLR8TT's Avatar
Try swapping coilpacks 1 and 2 with 3 and 4's coilpacks. If the codes show up on 3 and 4 then you'll know the coilpacks are to blame.
Old Aug 13, 2008 | 12:49 AM
TurboTT920's Avatar
Classic coil pack failure symptoms. My TT and my buddies 337 had exact same symptoms and we both needed coil packs
Old Aug 13, 2008 | 10:25 AM
gibson 01's Avatar
Ok. I am unplugging the ECU for 10 mins. then if it continues to mess up i will switch the coil packs. Thanks!
