!! Grinding Noise In Front Wheels !!
Old Mar 28, 2011 | 11:13 PM
IronCobra53's Avatar
Exclamation !! Grinding Noise In Front Wheels !!
My 2003 FWD is making a grinding noise when i make tighter turns, it wont make it all the time but it is starting to happen more often, the right front wheel bearing was just replaced last summer, dont think tht has anything to do with it though.
Also when i make a u-turn or a really tight turn sometime my car will make almost like a whining sound, and recently my steering has felt a little sloppy, not much different but a little, i checked my tire pressures and there good, as well as visually inspected it, but didnt see anything noticable, maybe its something in the power steering?
I need suggestions on what it might be?
Thnx in advance
Old Apr 1, 2011 | 09:58 PM
MCPaudiTT's Avatar
Sounds like it could be the ABS and/or ESP systems engaging. If it is overly intrusive, you may have a bad or failing longitudinal or transverse accelerometer - not an uncommon failure.
Old Apr 3, 2011 | 02:00 AM
thnx for the advice never thought about tht, im gettin it checked nxt time my car is in the shop
andrew.castaneda
Oct 10, 2014 09:40 AM
milo55041
Feb 28, 2014 12:33 PM
ivan22
Jun 5, 2009 06:37 PM
ryan
Mar 6, 2005 11:48 AM
