Haldex Badge
dont use a rasor blade use some fishing line. with a rasor you'll probably damage the paint. if you cant get some fishing line the use a toothpick. i used to debadge car at my old shop quite often, and paint chipping happens farely often and easy if you try to use hard objects to debadge.
+1 for fishing line. I did it that way before with great results (previous car). I also heated up the area where the glue was with a hair dryer (don't laugh, it worked and I don't own a heat gun) and it made them pretty easy to come off.
Just remember to wax where you debadge when you're done... Well I guess it wouldn't matter if you're just putting another badge in its place actually.
i'm pretty sure a flat toothpick will work or like you said fishing line
