Haldex Fluid Change & Throttle Blody Cleaning
Old Nov 11, 2006 | 12:52 AM
JewbinTT's Avatar
Default Haldex Fluid Change & Throttle Blody Cleaning
I ordered the Haldex fluid and filter.
Has anyone changed theres any pics and How To's?
How hard is it? where did you get the tool fot the Filter?
Next ?
Throttle Body Cleaning: Any How To's Pics etc.....
Thanks a lot for the help.
Jeff
Old Nov 11, 2006 | 12:55 AM
XCLR8TT's Avatar
Default RE: Haldex Fluid Change & Throttle Blody Cleaning
You can buy the tool from the Modshack. There is also a link on the page to a complete step by step.
I've done it once myself. It's not a bad job, you can do it off of jackstands, but it's easier with a lift.
Old Nov 11, 2006 | 01:09 AM
JewbinTT's Avatar
Thanks I think I will buy it. Ever clean your Throttle Body i have 2000 180 Q
Jeff
Old Nov 11, 2006 | 02:59 AM
XCLR8TT's Avatar
ORIGINAL: JewbinTT
Jeff
Yes, I cleaned mine a couple of months ago. surprisingly enough it wasn't that bad even after 78K miles.
Old Nov 13, 2006 | 06:44 AM
will_one2's Avatar
If you have a lift, the job is easy. Drain the fluid (5mm hex). While draining, use a long screw driver and hammer and tap the side of the filter and loosen it off. Do the same thing with the new filter. To add the fluid, cut the very tip of the bottle and insert into the drain hole as tightly as you can. Then use a long screw driver and push the liquid into the case. While holding the bottle there, have a extension and your drain plug ready in one hand. Then pull the bottle out quickly out of the way and put the drain plug as fast you can and you finish. Hopefully this helps.
audiblacky
Jan 27, 2023 05:43 AM
hotgrass
Aug 29, 2008 01:26 PM
jamt
Mar 13, 2008 12:52 PM
m5racer
Aug 20, 2007 08:22 PM
timbo108
Apr 28, 2007 09:37 PM
