Headlight sticks out...[need more help]
Old Jun 3, 2007 | 05:36 PM
theTTkid's Avatar
Default Headlight sticks out...[need more help]
The car has one accident (not me) under its belt and i have noticed that the passenger headlight sticks out a little bit... Ill try to get pics up to show exactly what i mean... Anyways, is adjusting it a DIY or no... im thinking it should be cause i just have to push in 1 corner a alittle bit, thanks!
Old Jun 3, 2007 | 05:44 PM
XCLR8TT's Avatar
Default RE: Headlight sticks out...
Pull the bumper cover off. You'll see an adjustment screw on the inboard headlight support bolt. You just turn the threaded sleeve that the bolt goes through to adjust the height for fit.
Old Jun 3, 2007 | 06:59 PM
theTTkid's Avatar
hmm alright, i may need some more help.. thanks though
Old Jun 4, 2007 | 12:07 AM
Murderface's Avatar
If you look around at some pics you'll see that more than just your TT's headlights are outta whack a little, I've seen others that stick out...don't feel bad lol
Old Jun 4, 2007 | 06:27 AM
chosos's Avatar
murder, what are you talking about? I really don't follow your post.
Old Jun 4, 2007 | 09:49 PM
theTTkid's Avatar
is there any way to adjust the way the headlight sits...not the alignment of it, without taking any of the body off
Old Jun 4, 2007 | 10:26 PM
XCLR8TT's Avatar
Nope.
Old Jun 4, 2007 | 11:10 PM
theTTkid's Avatar
lovely
Old Jun 5, 2007 | 09:29 PM
liTTo's Avatar
my drivers side is out some. probably from previous owners intake install. my outer tab is broken, gotta fix it and see if that helps.
tamtam69
Sep 16, 2013 05:07 PM
Emilgevor
Feb 16, 2011 11:32 PM
achTTung
Nov 5, 2009 05:36 PM
