Help!!!
Old Dec 6, 2008 | 12:28 AM
Trinion's Avatar
Default Help!!!
I installed a boost gauge and new my car is screeching for a second when you start it. The T fitting is between the manifold and the FPR. Is this normal or does anyone have any knowledge I can use?
Old Dec 6, 2008 | 12:36 AM
cincyTT's Avatar
I'm make believe
Those 2 things have nothing in common. It sounds like the starter is just making noise. There is a how to if you want to grease it down to make it quiter.
Old Dec 6, 2008 | 12:51 AM
Trinion's Avatar
starts then squeeks
Old Dec 6, 2008 | 01:06 AM
cincyTT's Avatar
I'm make believe
Oh, ok. You are probably just noticing the SAI (secondary air injection). Its the pump making that noise and your rpms will be ~1200rpms and then will stop when they drop to 800rpms.
Old Dec 6, 2008 | 10:35 AM
Trinion's Avatar
okay thanks, never noticed it before.
