Help with Airbag coding on 225TT
Old Oct 31, 2006 | 12:46 AM
Nautys's Avatar
Default Help with Airbag coding on 225TT
Airbag module is coded with 10102, which is valid for my module 8N8 909 601. CEL suggests buckles have failed 591/592 (and I get 'module incorrectly coded' - 1044), but testing both buckles using measure blocks VAG function shows them working correctly.
I've read postings for Airbag 8 systems which suggest 00307 should work, but I don't want to disable the module or cause a deployment.....I don't know that my module is an Airbag 8 system.
Any suggestions?
Old Oct 31, 2006 | 11:08 AM
XCLR8TT's Avatar
Default RE: Help with Airbag coding on 225TT
Have you checked the connectors on the bottom of the seats?
Old Nov 1, 2006 | 09:31 PM
Nautys's Avatar
Thanks, but yes I have removed the plugs under the seat and reconnected. There was no obvious contamination. It appears that the mechanism is working correctly because VAG com is sensing the belt buckle and changing state.
Do you have seat belt minder? - if so, what is your Airbag coding - you have a 2000MY 180 I believe?.
04BlackA8
Dec 30, 2010 11:29 PM
boostt
Apr 6, 2009 05:15 PM
kiberon
B7 Models
Feb 3, 2009 03:36 AM
themysteryman83
Oct 19, 2007 03:01 PM
02TTs
Sep 25, 2007 12:06 PM
