Help Electrical Problem
Old Oct 22, 2008 | 07:24 PM
andrew.bator's Avatar
Default Help Electrical Problem
I had this problem once or twice a long time ago and it just went away now it wont.....
Headlights, Fog lights, High beams, Heater Blower, Horn, Haldex, Turn Signals , Wipers don't work. Flashing High beams, Hazards, Parking Lights work.
I have no idea how these things are all related but they stopped working all together.
What I did as a temporary fix, I connected a wire from the fog light fuse to cig lighter fuse and that made everything work again. But I don't want to run the car with a ghetto fix because it might burn something.
Is there a relay, switch, ground, etc that I should look at?
I am looking through the Bentley wiring diagrams but I cannot find anything relevant.
Any help would be appreciated.
Old Oct 22, 2008 | 10:14 PM
jakej's Avatar
Check the grounds. Ground on the battery, ground by the fuese. Sounds like one of them came off, since so many things don't work, yet do work on a different circuit. Grounds near the headlight/horn/turnsignals too! I would guess one is loose. Another ghetto fix would be to shake the car up a bit to "reattach" the ground. Drive over some rr tracks or something. I bet it would fix it.
It's not a relay or switch, because too many things are related. That would be one huge high current relay.
Old Oct 23, 2008 | 05:34 PM
Default tinkered around
My grounds seemed to be fine so I tinkered around with the relays, I noticed that relay labled 53 would click with my ghetto fix so i took that one out and swapped it with another relay that was also labled 53 and everything works fine. So I guess the relay was bad.
What still stumps me is how everything else was effected.
Old Oct 23, 2008 | 06:11 PM
achTTung's Avatar
what location was that relay in?
Old Oct 25, 2008 | 01:35 AM
Default problem back
I get into car today and I have the same problem................Any ideas?
Old Oct 25, 2008 | 01:39 PM
jakej's Avatar
Yes. See my post above.
Old Oct 27, 2008 | 01:42 PM
kwaskow's Avatar
Try a ground from the engine block to the chassis.....can use a jumper cable to test
DurTTy
Oct 5, 2007 03:41 PM
steelcitysfinest69
Jul 24, 2007 01:42 PM
tbr76
Jan 13, 2007 02:14 PM
miabhai_freaked
Feb 22, 2006 11:12 PM
