help with headlight leveling sensor bracket
Old Feb 2, 2012 | 02:16 PM
rodhotter's Avatar
Default help with headlight leveling sensor bracket
removed bracket as per manual to install shock + spring not sure of orig install, the bottom bracket with U bolt rotates, can someone look under their MK I TT with hid option and check how bracket is mounted on their driver side trailing arm, the U bolt is on the left looking at it from rear, is the arm fastened to it on the top or the bottom of the bracket, thanks in advance bernie
Old Feb 2, 2012 | 03:31 PM
cincyTT's Avatar
I'm make believe
This one?
whats this lever thing in the drivers side wheel well? - AudiFreaks
They can be fine tuned with a 5mm hex on the housing also
Old Feb 2, 2012 | 06:32 PM
rodhotter's Avatar
Default headlight sensor mount
thanks but not it, its mounted on the drivers side trailing arm
TomKat
May 29, 2015 08:02 PM
Ncbaca
Oct 8, 2013 03:12 PM
a6xlr8s
Dec 9, 2010 08:16 AM
WoodShoe
Aug 30, 2010 05:17 PM
sony
Nov 18, 2007 11:17 AM
