Help me decide my next purchase...
Am getting the TT exhaust, and am trying to decide on getting lowering springs, or a front sway bar.
They cost the same, one will make the car LOOK better, and the other with improve the performance.... decisions decisions!
What do you guys think?
I have a 180FWD so i think the front sway bar would be more beneficial, and i agree with you about the stock struts, however i have a warranty, so i could get them replaced for free if they go!
I would be careful here...If the dealership notices those lowering springs they wont cover the shocks...When I bought mine the dealership said everything was covered then I looked that the fine print...sure enough after asking nothing would be covered as the car is chipped, lowering springs, and exhaust. The pretty much wipes out the warranty. i am going through that right now with the timing belt recall.
I had the whole tranny re done and the car was chipped, with an aftermarket DV and other visual mods. The dealership didnt give a ****! The lady who sold me it actually asked who i had it chipped with! If worse came to worse though, i would just put the stock ones back on before i took it in.
Rear sway bar is an hour tops, front sway bar took about 6 hours with a well equipped home shop. Rear first, front only if you need it. Four wheel alignment needed if you do the front SWB because you need to drop the front subframe and split the rack and pinion to pull and replace. Worth it if you have the time, tools and skills.
