Help me plz !!!
Old Sep 9, 2008 | 12:27 AM
00Audi180Q's Avatar
Member
Thumbs down Help me plz !!!
Hi, Guyz
I went to vw shop to flush out the coolants... they asked me about $129, looks fair deal so i ask them to do it... they called me 6 hours later that my coolants are burning up some reason(not leaking but getting short)
and they said my fans not working either...and freon r leaking...so they wanna put dyno and never answer back...
How long it takes to do dyno? I thought that less than 1 hr
is that cooling sys shows up on dyno? ...
I just feel like they r trying to rip me off...
Old Sep 9, 2008 | 12:43 AM
ouTTie914's Avatar
Well... Have you noticed if the temperature gauge was high?
Was your A/C cold before you brought it in?
Old Sep 9, 2008 | 09:38 AM
00Audi180Q's Avatar
Member
Default No...
No, it never get to high, always stayed on middle
yes, my a/c cold was not working when i brought it in.
Old Sep 9, 2008 | 10:33 AM
jakej's Avatar
Sounds like an expensive repair, if there really is a problem. I would check it out yourself or bring it to a different shop before you spent any more money. Maybe drive the car around for a day to test it??
Old Sep 9, 2008 | 10:52 AM
00Audi180Q's Avatar
Member
Default thx
Thx for help man..
I just found out it was waterpump/timing belt/freon/etc... lol
I have to replace it all of them..!@#%@
Old Sep 9, 2008 | 01:04 PM
jakej's Avatar
I don't understand how a waterpump would cause the coolant to burn. Sounds more like a headgasket. Maybe it was just leaking?
Old Sep 9, 2008 | 05:04 PM
00Audi180Q's Avatar
Member
Default NO..
They said no leaks, and said if will be fine after changing waterpump & belt.
I got to change them anyway so i just let them do it.
ye.. I also do not understand what they are talking about..
Old Sep 10, 2008 | 09:01 AM
XCLR8TT's Avatar
If the water pump isn't moving coolant through the system, engine will get very hot and "burn" the coolant. The stock water pump has a plastic impeller, which by 50 or 60K miles is pretty much shot.
