Help me Spend Some Mulla!!
Old Mar 1, 2008 | 08:02 PM
achTTung's Avatar
Default RE: Help me Spend Some Mulla!!
Uhhh, I though the amp was tucked low behind the rear seat near the first aid kit?
Old Mar 1, 2008 | 08:09 PM
Red_sapphire89's Avatar
It is but the stock head unit has a "chip" that powers it...its a complicated mess to explain but a aftermarket headunit will work just fine with stock speakers they just wont sound as clear..
Old Mar 1, 2008 | 11:23 PM
themysteryman83's Avatar
Mobius97, either you had an ignorant salesman or he was trying to take you for your money, or both. An aftermarket headunit works fine in the TT with a few accessories. Here's a couple of good write-ups about the install.
http://www.fourtitude.com/news/publi...ter_1972.shtml
http://public.fotki.com/martt/audi_tt/mods/radio/
Don't be fooled. The stock Bose system actually sounds pretty good, but you can't bring out its potential with the stock headunit.I did this myself and it wasn't too hard. The hardest part is fitting everything in there behind the headunit.The stock headunit uses preamp outs, which is unusual for a stock unit. Basically, these are the RCA outs you see on the back of aftermarket units. Usually stock units use line level outs.A Metra 1787 adapter will let you turn the stock harness into preamp outs you can use with an aftermarket unit. You will also need a ground loop isolator, otherwise you will get aloud pop everytime you change a station or source. You will need the front plate adapter so you can mount the headunit into the stock space.If you have any questions about the install feel free to PM me. BTW,an aftermarket headunit makes the Bose systemsound fantastic! The Bose amp will sound better than any aftermarket onboard amp ever will.
Old Mar 2, 2008 | 07:28 AM
dale55's Avatar
ORIGINAL: themysteryman83
Which aftermarket head unit did you go with and how much was the install?
dale
Old Mar 2, 2008 | 12:00 PM
Pioneer deh-p7900bt. I got about a 40% discount on the headunit and rediclous discounts on the accessories. The headunit was retail $420 and the accessories would total about $60 + tax. I did the install myself in about 3 hours. Here's a pic:
Old Mar 2, 2008 | 01:00 PM
Mobius97's Avatar
Mysteryman...thanks for the info, I appreciate it. Time to start shopping around again!
DryFire
Jan 26, 2018 02:08 PM
Lindb8
B8 Models
Mar 19, 2015 03:14 PM
Teamwilson
B8 Models
Jul 29, 2011 08:20 AM
Username510
Apr 30, 2011 08:27 PM
audilover04
Jul 28, 2006 03:35 PM
