Help with Wiring -- Splicing
Old Mar 18, 2008 | 01:45 PM
DurTTy's Avatar
Default Help with Wiring -- Splicing
hey does any here have an ecm wiring diagram and also any wiring diagram that will display which color wires i can tap into for:
engine speed, Throttle positioning, injector duty cycle
i think thats it. basically i need to tap into these readings and any wiring diagram/help is really appreciated.
Old Mar 19, 2008 | 08:39 AM
DurTTy's Avatar
Default RE: Help with Wiring location
well i managed to locate each wire at the ecu and also color match them etc etc.
so now the new task becomes as follows.
HOW TO TAP ITO THEM?
i could use the wire taps, and shrink wrap.
any other ideas, im wondering if thre is anything i could use to tap into the wire at the pin connector ( at the clip) like somehting that slides into the pin slot or so .. any1 here know of any such thing? ( which requires no cutting or splitting of ecu harness)
Old Mar 19, 2008 | 06:33 PM
jakej's Avatar
I'd have to see the connector to let you know your options, but most require a very expsive tool ($400+). I would cut the wire, solder, and heatsrink. It'll be fine.
Old Mar 19, 2008 | 06:41 PM
ouTTie914's Avatar
Mind if I ask why you're doing this?
vtraudt
Oct 10, 2013 01:33 PM
kev813
Apr 5, 2013 07:59 AM
trev123
Mar 29, 2013 01:54 PM
tmanley
Aug 26, 2009 10:58 PM
Mya4T
Oct 23, 2007 06:15 PM
